Originally posted by Beau I can recommend the HCFR tool with an X-rite Display2 colorimeter. It's not that hard. I used it to calibrate my Samsung TV which has a full CMS (color management system). There's no need to go into the service menu.
If you use a pc as an input device, you can create a color profile as you would for a normal pc monitor. I did this to correct the small remaining calibration errors. I can highly recommend DispCalGUI over the software which comes supplied with the colorimeters.
Nice- hadn't run across DispCalGUI- that looks like a good one!
My LG also has the color management stuff available at the user level- its becoming more common on the higher end units.
