Originally posted by goldenarrow Tried using it at the beginning after raw conversion and every example had harsh artifacts amplified the more PP I did.
I use FM in PSP X. My workflow:
1. Do whatever I can do in the SilkyPix Pro 4 raw converter as it's closer to the source and in 16-bit. (I always shoot raw.) No sharpening, NR or output USM sharpening if I'm going to use FM - export as 16-bit TIFF.
2. In PSP X, apply Clarify (if suitable) - it's a 16-bit operation.
3. After Clarification (if any), convert to 8-bit and apply FM. (Only 8-bit plugin support in PSP.) I think it's best to apply FM to the unsharpened, full-size image. Max. radius would be 5px-6px, usually 2px-4px. sometimes 1px. I l look at the lips & eyes. When I see a halo, I back off. It's better to under-compensate then it is to over-compensate. Sometimes the halo is just visible in the magnified preview but not in the final version.
4. Apply duplication/resizing if sending a copy to the web.
5. Apply output USM, if needed, on the various sized versions of the original (after resizing, of course).
If a picture is noisy, I usually denoise it in SP and forego FM.
Dan.
