Originally posted by raider Hi,
I know this is a much discussed topic before and i have STF but still rather confused..so I will post the question again.
I just bought Topaz Denoise and Infocus (Infocus is only $30 bucks!) and using it now with PSE7. I am also test driving silkypix and much prefer the raw converter from silkypix than Adobe Raw.
My current workflow is to tag/keyword the photos using PSE7 and then drag the photos to Silkypix for the exposure adjustment, saturation, curves, etc. Now with denoise/infocus added into the picture (and I read that we should really apply NR as the first step of the workflow), I am confused.
If I use PSE to run denoise first, PSE will not be able to save the output to a DNG file but either TIFF/JPG/etc...so the question is...how do I "export" the denoise process DNG file to Silkypix and have silkypix processed the raw file to output to jpg?
I know this is a silly question but really on my wits end here. Appreciate help.
Thanks
raider
if you personally prefer to do your raw conversions in SilkyPix then just do not do NR in SilkyPix at all (or may be just a little of choma NR using "False Color Ctrl" slider) - export to .TIFF and finish it in PSE w/ Topaz Denoise, etc.
Topaz Denoise plugin in any case does NR on already demosaicked data, so if you are using it - it can't be a "first" step anyways
... even if you are using ACR (PSE is using ACR to open and convert raw files) your Topaz Denoise is working in fact,
implicitly, with the "TIFF" file, just w/o explicit step of saving (from ACR)/opening again (in PSE).
