Originally posted by slip the bigger the photo and the more resolution it is, the smaller the font will appear on the pic. also different fonts are different sizes for the same dpi.
If you work to print, 300-320 dpi should be enough.
Is it possible the invisible text is just on a layer below the one visible?
cheers
That is possible that the text was under a layer. Sometimes I get confused on how to get a certain layer on top. Shouldn't the text automatically be on top though?
Originally posted by kurki As to not seeing the text when you type, make sure the colour of the text is set to black.
I think it was set to yellow when I couldn't find it.
