Originally posted by johnmflores If the magazine is good, they'll do what they need to make sure that your photo doesn't end up with a color cast due - a bluish tone due to too much Cyan, a purplish tone due to too much Magenta, or a sepia-like tone due to too much Yellow. They do this stuff every day and should know the press and the paper and the inks that they are working with.
Or worse, they do this stuff every day so don't give a crap about what it looks like!
Most likely you won't see a
single color cast over the whole image, but rather different color casts at the highlights/ midtone/ shadows. The reason is that the CMY colored inks are all being dropped down with Black (K), but the dots are not in the same places due to the "screens" used to avoid overflow, which are based on the density desired.
In general, CMYK printed black/white images have shadows that will tend to run brown (magenta floating on the black), and midtones blueish (cyan peeking through), and highlights all over the place based on what channels are clipping first. Mitigation of these is a tough separation job, and most places outside of fine-art bookmakers don't put the attention into it. If you're lucky, they'll push it to grayscale (and empty the CMY) and let their black plate do it all (a little weak in the shadows, but no casts!).
I've frequently done custom separations where I pump up the Black and tone down the CMY using brightness/contrast on each individual channel - but I've worked with 4-color seps for decades and I know the printing processes backwards-forwards.
Bonne chance!
