04-25-2011, 01:28 AM   #1
kiwi_jono's Avatar
Raw processing with Linux?
Hi, I'm a Ubuntu Linux person these days and so enjoying it.
While I normally shoot with JPG, I realise that I can get a bit more flexibility shooting raw.
I have tried opening PEF files with Gimp, which it does (with a few errors / warnings) but, while I like Gimp, is there a better approach?
Are there Linux users out there processing Raw files and if so what are you using?
04-25-2011, 02:30 AM - 1 Like   #2
Emacs's Avatar
Darktable is the best IMO
04-25-2011, 02:34 AM - 1 Like   #3
I use, and love Rawtherapee...and you should use DNG, you can have troubles converting PEF since it's usually not supported in linux RAW conversion software.
04-25-2011, 03:34 AM   #4
kiwi_jono's Avatar
Thats great. Thanks. Will look into them.
04-25-2011, 05:40 AM   #5
marcinski's Avatar
Make sure you try Bibble. There is a trial version available.
Marcin
04-25-2011, 06:08 AM - 1 Like   #6
Ufraw + gimp has worked quite nicely for me for the actual processing. Occasional problems (a strip of junk at the right edge) with K-5 .DNGs though. Should see whether there has been an update though. With ufraw the thing to discover was that gamma needs tweaking, gamma=0.35 and linearity=0.063 would seem to produce results that are reasonably close to camera JPEGs with the default settings with both the K-x and K-5.
04-25-2011, 07:09 AM - 1 Like   #7
QuoteOriginally posted by jolepp Quote
+1 for UFRaw. BTW, the pink "strip of junk" and gamma issues mean you need to upgrade to 0.18, as older versions don't support the K5.
04-25-2011, 07:19 AM   #8
Emacs's Avatar
QuoteOriginally posted by marcinski Quote
Marcin
I have bible pro licence, but I switched to darktable, it's just better.
04-25-2011, 09:09 AM   #9
+1 for bibble. I evaluated most everything out there. It's the first piece of software I've purchased in 8 years. That should tell you something.
04-25-2011, 12:45 PM   #10
kiwi_jono's Avatar
So many great options - thanks.
So far have tried Ufraw and darktable.
Ufraw seems to work Ok.
Darktable (V0.8) seems to show images all blue looking (its like the colours are negative of what they should be or something). I'm running Ubuntu 10.10 64bit - anyone had that issue?
04-25-2011, 01:57 PM   #11
marcinski's Avatar
QuoteOriginally posted by Emacs Quote
Thanks, I'll give it a try,
Marcin
04-25-2011, 02:33 PM   #12
Emacs's Avatar
QuoteOriginally posted by kiwi_jono Quote
DNG? If it is try to compile DT from the master, or wait for newer DT build from the unstable PPA.
04-25-2011, 03:56 PM   #13
kiwi_jono's Avatar
Yes DNG.
Resolved by installing "unstable" release! looks good.
04-25-2011, 06:11 PM - 1 Like   #14
Darktable is my RAW converter/manipulator of choice. Kind of geeky but once you get the hang of things it is extremely powerful. And the images it produces are superb.
Jack
04-25-2011, 09:52 PM   #15
kiwi_jono's Avatar
Indeed I'm liking what I am seeing with darktable.
I can see I will be shooting a lot more RAW now!
files, gimp, linux, photography, photoshop
Linux: batch raw conversion script w/ ISO-dependent processing Quicksand Digital Processing, Software, and Printing 8 07-14-2016 11:53 AM
Processing RAW files in Linux (Ubuntu) krishna Troubleshooting and Beginner Help 9 04-23-2010 10:58 PM
K-7 Raw processing on linux; dull colors K7er Digital Processing, Software, and Printing 10 03-08-2010 07:45 PM
Linux -- Ubuntu Karmic 9.10, libraw 0.8.5, Raw file processing K7er Digital Processing, Software, and Printing 4 01-13-2010 08:35 PM
RAW Processing in Linux soprano Digital Processing, Software, and Printing 21 07-20-2009 03:43 PM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
