Originally posted by emalvick Some questions for the OP:
1. Are your JPGs looking better in Lightroom after exporting them? Are your JPGs looking different in another software? If so, which software?
2. Are you changing colorspace when you export from Lightroom?
3. Do you calibrate and profile your monitor?
Thanks for the reply and help... here's some answers to your questions.
My process to date is minimalist and straightforward, and goes something like this:
- Import all pictures from card
- Preview all images at "to fit" size (approx 720 on the long edge in my setup)
- Flag (F) those images that look "worthy" (focus, composition, interest)
- Select all flagged photos
- Export to Flickr "set" as JPEG
In terms of the export settings, it exports at 90% quality (versus the default 80%) and that's it. No other sharpening / resizing is happening as part of the export.
The photos arrive at Flickr and look fabulous -- better than in my preview. For those more experienced in PP and digital photography in general, perhaps the difference is expected and/or understood. I was just surprised at how much better they looked.
Regarding the colorspace, I do not believe I am changing that. But I will check the camera colorspace (which I think is sRGB) and the space used in LR and the conversion to JPEG.
As for calibrating the monitor, I'll make two comments.
- I am familiar with the process, working with both Mac and Windows, the color rendition between the two is dramatically different; a difference exasperated by different monitors too. I have not calibrated my current monitor (on Windows, where I am using LR)
- Calibrating the monitor would affect all color, regardless of file-type, as it is a hardware configuration process, affecting the rendering of all pixels output to the device. i.e. if the color is right on my JPEG, it should be "right" on my RAW preview -- assuming the preview is in the same colorspace and presenting the same color in the same saturation with the same contrast etc., etc. ... which at this point, I think we know it is not.
Anyway ... I'll continue to review my settings and see if there is anything to tweak to enhance the previews a little. Regardless, my goal here was to seek a little understanding from fellow members (thanks all!) and draw attention to the issue for newcomers to DSLR, LR and PP in general, as none of us want a good photo to go unprocessed just because the preview was a little lackluster!!
Cheers!
