Originally posted by HenrikDK Marc - a BIG thank you for you comments and advice.
You're welcome! I definitely remember when I was where you are now, and how incredibly empowering it was to finally be getting somewhere with all this.
Quote: One question: Sounds like using DNG is the way to go, but I saw a couple of posts (mostly older) that claimed PNG produced better results. If I understand this correctly there should be NO difference in resulting image quality? ANY reason to use PNG rather than DNG, other than the slightly smaller file size?
I suspect either you or the other posters you refer to are misunderstanding something. DNG is a raw file format, as is PEF. PNG is *not*. So no, PNG is not going to be anywhere near as good as DNG, at least for the things where RAW is useful. Sometimes people accidentally type PNG when they mean DNG, and perhaps that's where the confusion comes from, but PNG is *not* something you'd be dealing with normally except perhaps as final output after processing your RAW files (whether DNG or PEF).
PNG is it's like JPEG, but with a lossless compression (so quality is ever so slightly better, and file sizes are correspondingly bigger), and no support for IPTC. It's basically used for one thing and one thing only - web display.
It's also possible they meant to be comparing DNG with PEF. In theory, they are the same data just packaged in different ways, but any given release of any program might happen to treat them slightly differently in terms of how they render that data. Neither is inherently better or worse.
The reason Krogh is so big on DNG is that it is "standard" (well, openly documented, and has been submitted to ISO for standardization), that it can include IPTC info in the file itself rather than require a sidecar XMP file, and -= most importantly - that it can contain a "corrected preview" (a JPEG that reflects the adjustments you've made). The latter means that any program displaying the DNG file would be able to see the adjustments you made, which is not true of PEF.
I personally find I like working in PEF better, though - I like the idea of never actually modifying the original file. I never view my DNG files with any program but the one I use for my processing them (ACDSee Pro) so I don't care about embedded previews, and I have no issue the fact that my metadata is in sidecar files - I've been using sidecars in some form for as long as I've been using computers (like, over 30 years now). If I ever did move to a different program for managing my images, I might want to see the corrected previews I made with ACDSee, but I generate JPEG "proofs" of all the images I've processed and I mostly interact with those, so my adjustments would continue to be visible there. ACDSee also generates full size previews for use with the PEF files (stored in a subfolder), and if need be, I could eventually generate new DNG's that embed those previews. So I don't feel I'm losing a thing using PEF instead of DNG.
