06-02-2011, 08:43 AM   #1
Emacs's Avatar
Any idea how to get rid of purple fringing using tools available in GNU/Linux?
Click image to get the original copy.
Can someone advise me hot to get rid of this fringing?
06-02-2011, 09:16 AM   #2
Have you tried Darktable? IIRC, it uses rawtherapee's amaze demosaicing algorithm and might automatically get rid of fringing and/or chromatic aberration....assuming you shoot RAW.
edit: Looked at the exif and I see you did use darktable. That was my best suggestion.
06-02-2011, 10:32 AM   #3
Guest
Guest
Normal chromatic aberration corrections don't normally work on purple fringing--especially if you're using a manual lens for which there is no automatic correction (the function in darktable requires data from the lens AFAICT). I've achieved good results with the hue-saturation control in GIMP. Just lower the saturation of the magenta and blue channels--this works fine for many subjects. Here's a before and after crop of a shot taken through an SMC Takumar 50mm f1.4.
06-04-2011, 01:49 AM   #4
Emacs's Avatar
Thank you, nevermindhim, this approach seem to be adequate enough.
photography, photoshop
Does the K5 Amplify Purple Fringing? PixleFish Pentax K-5 & K-5 II 27 01-07-2011 01:48 PM
Purple fringing with 31ltd DanielT74 Pentax SLR Lens Discussion 7 11-05-2010 06:11 AM
Purple Fringing stevewig Digital Processing, Software, and Printing 13 09-08-2010 01:01 PM
DA40mm and purple fringing trevorgrout Troubleshooting and Beginner Help 9 07-10-2010 03:46 PM
Purple Fringing on Film glasbak Pentax SLR Lens Discussion 8 10-05-2009 08:24 AM
All times are GMT -7. The time now is 03:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
