Originally posted by Marc Sabatella If those are images produced by an Adobe product from a DNG file, then ACR most definitely created them. And there is no such things as a DNG image with no processing applied. If you can see it, then it has neen processed. An unpocressed DNG file cannot be displayed on an RGB monitor.
Originally posted by wildman There is no "actual DNG", at least visually, only various software interpretations of the data in a RAW file. A RAW file is not an image file like JPG is but just a simple binary data file so far as I know.
Jeff Schewe
Real World Camera RAW with Adobe photoshop CS5
I understand what both of you are saying.
Quite coincidentally, just after I opened this thread, I came across some comments that propmpted me to install onOne Software's "Presets for Camera Raw". Three of the presets are labeled Reset Auto, Reset Default, and Reset Zeroed. The first two, as would be expected, produce results corresponding to the Auto and Default options in ACR's Basic panel, respectively. The Zeroed profile produces an image that is similar to what one sees with Fastpictureviewer's and Faststone's "actual RAW" (using my terminology) displays.
This leads me to understand that adr1an's comments in post #2 must have some validity:
ACR applies a bunch of defaults based on the embedded profile in the image.
PDCU applies the same 'settings' to the RAW file by default that the JPEG version would have gotten.
In other words, ACR, by default, processes the image aiming for some specific results as its objective, whatever that objective may be, and the "Reset Zeroed" profile changes that objective, and I'd be curious to know what each of these objectives is.
