Originally posted by Buddha Jones Yes, say there is a routine that you go through everytime you pull images off of your camera. Lets say you resize it, then crop it, then change the DPI on it, then do an unsharp mask. I can write an action that will do each part of that for me or all of it in one sequence.
How it works is you do it once to one photo and set up PS to record your 'actions' and then save it. Then you can run that saved action against any other file. Pretty handy feature.
Yep, Lightroom calls them "presets". You can apply their presets to a shot or make your own from a sequece of steps, which become available to be applied to other pics from a number of locations. You can apply it one @ a time in the Library or Development mode, or to a set of images in Library mode. To creat sets, you can tag &/or color code and filter, and/or create collections, to easily create different sets/sub-sets, and apply different 'workflow' steps' to them; for example I had presets for Elephants and different ones for Zebras and different ones for every amimal type, with two or three of each depending on the exposure or contrast level of the original picture. It [LR] really is made for everything but heavy duty selective/layered image processing. Soupa Duopa Kewl...
For that, you already know what to do.
