Originally posted by mcut
i plan to just shoot raw and am finding it difficult to work out what i should do with the raw files to get the software to mimic the JPEG that the camera would create, do i need to be "creating" a curve on the raw file using that graph and then putting the images in the queue for processing. it is not the most intuitive software but i understand it does quite a good job, especially as it is free!
I'm afraid your previous software is not very relevant to DCU4. The way DCU4 works is very simple. The raw data is displayed with all camera settings (image tone, contrast, sharpness, white balance etc) exactly as they were in the camera when you took the photo. If you do a straight conversion (Save As), all of these settings will be written to the jpeg. In other words, the converted raw photo will look pretty much identical to a camera produced jpeg.
Note though, that the camera settings are not set until you do the conversion. Let's say you shoot a mountain vista with Natural image tone, all other settings (saturation, sharpness etc) set to defaults. The photo will be lack pop, it will be a little drab. So in processing, you change the image tone to Landscape, with maybe an extra nudge in contrast, and you warm up the white balance. Now if you do Save As, the jpeg will incorporate the new DCU4 settings. No settings are written to the raw photo, they are still fully adjustable, so you could process the shot in a number of different ways, saving each resulting jpeg with its own name (or overwriting a previous copy if you wish).
If you use Extract JPEG, the settings will again default to the original camera settings, none of the DCU4 settings will be incorporated. Another thing to be aware of with Extract JPEG, is that the compression is very heavy. With my K20D for example, a 20MB raw file, which may end up around 6MB using Save As, will only be about 1MB if I use Extract JPEG. Not great for printing.
I hope this answers your questions.
