The Lenovo X220 12.5" is currently available with an IPS panel, its the only one i've seen.
but....
1) its tiny
2) its very expensive
3) only the i7 version has USB 3.0
4) no dedicated graphics card (but it has 6GB up to 8GB)
5) its very expensive
However there is a black Friday special on somewhere on Amazon (US only) for about $1100 as opposed to $2000+ here. No thanks.
The ASUS U36SD - DH51 looks pretty good i5 2nd gen 4GB (easily changed to 8GB) it does have a graphics card but a pretty low spec one as far as gaming goes. The GT520M is only slightly higher rated than the i5-2430 spec HD3000 integrated unit.
The ASUS U46SV - DH51 for the same money but higher spec same i5 + 8GB + GT540M is also tempting. Pity the hard drives are only 5400rpm and a buried deep inside on these 2 so more tricky to replace.
I also like Toshibas R830 series, thin & light, decent full voltage processor, & includes a DVD, but no dedicated GPU.
I like Tohibas as I've had 4 Tecras in the last 12 years and theyve been worked hard too (environment-wise). One died a noble death in a factory buried in cement powder.
I'm questioning if it really necessary to have a dedicated GPU for "normal" processing. I won't be doing Gigapixel panoramas.
The copy of LR3 I had installed installed on my work machine is set to use the Integrated GPU by default, and it worked fine for me.
I only discovered this by starting the program "Right Click" > "run with graphics processor" and either can be selected with the default setting of the integrated one.
The 3D AutoCAD packages I'm also running on the machine use the dedicated unit by default. So do various video players of course.
I also note that all the half decent GPU's seem to be only in bigger units 15.6" - 17" for higher res FHD screens and easier cooling for the GPU.
Anyway, thanks for the input so far, but I'm still uncertain about the dedicated GPU.
i5 or i7 processor (tick), 8GB (tick), USB 3.0 (tick), fast HDD? .. hmm replace with 7200 or SSD
PS: If I can convince the IT guy to let me run VMWARE on my machine I can install myself and run LR3 as an administrator on the virtual machine and be totally isolated from my (now secured) work PC. ( i7-2720QM 2.2GHz , 8GB , GT540M -2GB, 750GB at 7200rpm, 15.6" 1920x1080 glossy
Has anyone run Lightroom or CS on virtual machine? eg if you have 2 different operating systems Mac + Windows on the same machine.
I've seen it done before, running Windows based PLC programming software on a MacBook in VM environment.
Edit: I think jolepp & ClassA (in the last 2 posts) just explained why when i spoke to Adobe they didn't stipulate a dedicated GPU for running LR. As long as integrated processor can "share" enough memory for graphics if it needs to. Thanks.
