Agreed, its always better to compose and shoot with a non-fisheye, but defishing the 10-17mm can work, especially at 17mm. I used to defish more often, before I bought my DA15mm. These are from a year and a half ago, from the old city in Jerusalem, shot with the 10-17mm. At the time, I tried defishing all of the photos from that outing, but in the end, decided to stay with the non-defished versions for all of the photos. I have very accurate profiles for the 10-17mm fisheye correction correction, that I generated with ptgu 360 degree panoramas. Defishing at 10mm doesn't work that well, due to stretching and cropping, (8mm rectilinear equivalent, based on vertical FOV).. Defishing at 17mm works (15mm APSC rectilinear equivalent). Defishing at 14mm can work, (12mm APSC rectilinear equivalent). In the end, I generally prefer to use the 10-17mm without defishing. It is a good "get it all in lens", which is something that regular rectilinear wide angle lenses don't do as well. Also, the wider you go, the more the defishing changes the image to one that is sensitive to the pitch. Rectilinear ultrawides also act really wierd; and for me, the widest I like to go is my DA15mm.
- Shel
10-17mm, 17mm example
Defished 17mm example, equivalent to 15mm APS-C.
10-17mm, 14mm example
defished 14mm example, equivalent to 12mm APS-C, defished to a 3:2 aspect ratio.
10-17mm, 10mm example
defished 10mm example, equivalent to 8mm APS-C, defished to a 3:2 aspect ratio, which also crops the ultrasoft defished edges.
One more example at 10mm,
defished, this photo is probably sharp enough for the web.
