Hi all,
I'm hoping this is just something i'm overlooking. I'm trying desperately to get my wife off of Picassa (the last file I went to look at was amusingly named IMGNNNN.DNG.JPG - yeah, no idea what it may be doing there
), and onto using LR full-time, but she brought up what is one of my biggest annoyances to date with LR.
If you are using clone/heal, let's say for removing shadows underneath eyes, or filling in an errant spot of skin that hair isn't covering, in Picassa, you can select the area, alter the brush/circle size, grab from an area to blend into the selected area, and apply. So far, it's functionally identical between LR and Picassa.
However, some areas require more than one pass in the same area - I guess you could bring it into Photoshop to use a more brush/stroke oriented fix, but Picassa let's you re-select a previously cloned/healed area, to do an additional pass over it, meaning adding a new 'layer' of clone/heal on top of the prior one. LR does not seem to allow this, and will only 'grab' the prior clone/healed spot instead, and while it will allow you then to adjust the size and opacity of that cloned/healed spot, there seems to be no way to add a second layer on top of the first, except for overlapping somewhat with an additional clone/heal.
As a result, I've got to say, retouches of this nature tend to come out a LOT better with Picassa than with LR.
Any suggestions or help on this one? Is there a key combo or option I could enable to work around this?
