Originally posted by bjake Marc,
Thanks,probably seems like a dumb question to most everyone else but something I needed to know.Shot some today saving both jpg and raw,will process the raw to see if I can come out any better with it.
Thanks,
Jake
Remember - if all you do is do a straight conversion with no adjustments, there should be no significant difference, depending on what program you use to do the conversion. No difference whatsoever if converting using the Pentax software.
The only way you will see a difference is if you do some adjustments on the RAW file before converting to JPEG, then perform the same sort of processing on the shots you took in JPEG. For small adjustments, there will still be little or not discernible difference. But trying doing something like changing WB from tungsten to shade, or pushing the exposure by 2 EV, or a similarly extreme curve manipulation, and the difference will be quite clear; Performing those operations on JPEG won't produce nearly as good results as performing them on RAW.
