01-03-2008, 04:32 PM   #31
Rickster's Avatar
QuoteOriginally posted by Jens D. Quote
It's hard for me to decide which data are useful for the user, and which data are useless.
For one, the informations about the battery could be useful, for others it could be useless - that's why I show all informations and let the user decide which informations he want to see.
Cu, Jens
Thanks for dropping by Jens. You have written a great program!
Some things I would enjoy seeing in the program ...
I'd like to left-click the thumbnail to bring up a larger (user selectable size) image with the focus point overlay. While in this mode the current RGB values would be displayed for the current cursor location.
I'd like to use the left-right arrow keys to select the previous-next image in the current working directory.
I'd like to be able to right-click a tag ID and select display suppression for that tag. The suppression data would be maintained in a unique 'suppressed tag' file for each camera model.
01-04-2008, 02:51 AM   #32
Hello!
QuoteOriginally posted by LeoTaylor Quote
The File, Edit, View,..., Help menu bar is an industry standard. I'd bet some of the readers just looked up at the top of their browser and saw: File, Edit, View,..., Help .
I don't like programs with hundreds of menu items and sub menu items, and sub menu items of the sub menu items, so that you need to search what you are looking for.
The "design" of PhotoME is very common in Windows. It's used in the Control Panel, in the Search dialog, in many places in the Windows Explorer, Help menu and so on.
But if PhotoME get more features, maybe some day I need to do a menu too.
QuoteOriginally posted by Rickster Quote
Thanks for making PhotoME public.
That's already on my to-do-list for one of the later versions.
I'll think about that for one of the next releases.
If everything works well, the next version will have an integrated file browser mode with preview images, so switching between the images will be easily possible.
That's a great idea! I'll put this on my to-do-list with high-priority.
Thanks for your feedback!
Cu, Jens
01-06-2008, 07:01 PM   #33
prof68's Avatar
Looking at the first shot I took with a new K100D Super the shutter count shows 336. I'm assuming this value is for the number of shutter releases. If that is the case it seems as though Pentax tested the camera before it was packaged or the value is incorrect.
On a side note my camera was built the day after my birthday.
01-06-2008, 07:13 PM   #34
Rickster's Avatar
QuoteOriginally posted by prof68 Quote
I'm sure they fire off the shutter many times at the factory while calibrating the camera.
My K10D had 290 shutter releases from the factory.
01-06-2008, 07:32 PM   #35
After seeing this program mentioned several times on this site, i downloaded it today. All I can say is, WOW, that's a lot of info it gives you! Very cool program. I was surprised to see my *ist DL has 6060 shutter releases. I knew I shot a lot at events, but didn't realize they added up so soon.
Great job on the program!
01-07-2008, 02:43 AM   #36
fishy's Avatar
Pretty cool stuff! I've spent a LOT of time trying to extract EXIF data using PHP, and the common stuff is easy enough to find, but the camera specific info.. Brrr.
Unfortunately I do not have a Windows machine at home (yup, Mac).. Anyone know if there's a plugin around to show same info in Lightroom?
01-07-2008, 04:54 AM   #37
had a dig about...
being a mac user the afforementioned PhotoME isnt so terrific for me HOWEVER i have managed to extract all the info from my photos
very cool
i am in the process of writing myself some cool scripts for nameing all my files with the relevant info that i want in them.. since my camera cant do it.. ill do it when i import them...
below is the basics i get from a picture...
File Name : aaa.dng
Directory : .
File Size : 16 MB
File Modification Date/Time : 0000:00:00 00:00:00
File Type : DNG
MIME Type : image/x-raw
Make : PENTAX Corporation
Camera Model Name : PENTAX K10D
Orientation : Horizontal (normal)
Software : K10D Ver 1.30
Modify Date : 2051:11:12 02:44:20
Image Width : 3936
Image Height : 2624
Bits Per Sample : 12
Compression : Uncompressed
Photometric Interpretation : Color Filter Array
Strip Offsets : 137252
Samples Per Pixel : 1
Rows Per Strip : 2624
Strip Byte Counts : 15492096
X Resolution : 72
Y Resolution : 72
Planar Configuration : Chunky
Resolution Unit : inches
CFA Repeat Pattern Dim : 2 2
CFA Pattern 2 : 0 1 1 2
CFA Layout : Rectangular
Black Level Repeat Dim : 2 2
Black Level : 0 0 0 0
White Level : 4095
Default Scale : 1 1
Default Crop Origin : 8 8
Default Crop Size : 3872 2592
Bayer Green Split : 0
Anti Alias Strength : 1
Subfile Type : Reduced-resolution image
Primary Chromaticities : 0.64 0.33 0.21 0.71 0.15 0.06
Y Cb Cr Coefficients : 0.299 0.587 0.114
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Y Cb Cr Positioning : Co-sited
Exposure Time : 1/350
F Number : 8.0
Exposure Program : Program AE
Date/Time Original : 2051:11:12 02:44:20
Create Date : 2051:11:12 02:44:20
Flash : Off
Focal Length : 28.0mm
Sensing Method : One-chip color area
Custom Rendered : Normal
Exposure Mode : Auto
Focal Length In 35mm Format : 42mm
Scene Capture Type : Standard
Subject Distance Range : Distant
DNG Version : 1 1 0 0
DNG Backward Version : 1 1 0 0
Unique Camera Model : PENTAX K10D
Color Matrix 1 : 2.322891235 -0.8227081299 -0.3182067871 -0.4585418701 1.231063843 0.08865356445 -0.08618164063 0.1678466797 0.3913574219
Color Matrix 2 : 1.098602295 -0.2572631836 -0.03800964355 -0.5685577393 1.259155273 0.2501525879 -0.06753540039 0.06077575684 0.977935791
Analog Balance : 1 1 1
As Shot Neutral : 0.6037735849 1 0.8858131488
Baseline Exposure : -0.5
Baseline Noise : 1
Baseline Sharpness : 1
Linear Response Limit : 1
Pentax Version : 3.0.0.0
Pentax Model Type : 0
Preview Image Size : 640x480
Preview Image Length : 26706
Preview Image Start : 32558
Pentax Model ID : K10D
Date : 2051:11:12
Time : 02:44:20
Quality : RAW
Flash Mode : Off; Internal
Focus Mode : AF-S
AF Point Selected : Top
ISO : 100
Exposure Compensation : 0
Metering Mode : Multi Segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Auto
White Balance Mode : Auto (Daylight)
Saturation : Normal
Contrast : Normal
Sharpness : Normal
World Time Location : Hometown
Hometown City : Pago Pago
Destination City : Pago Pago
Hometown DST : No
Destination DST : No
DSP Firmware Version : 1.30.00.18
CPU Firmware Version : 1.30.00.18
Effective LV : 14.4
Picture Mode : Program AE; 1/2 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Color Space : Adobe RGB
Image Area Offset : 8 8
Raw Image Size : 3872x2592
Preview Image Borders : 26 26 0 0
Lens Type : Tamron 35-90mm F4 AF or various SIGMA models
Camera Temperature : 27 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0
Image Tone : Bright
SR Result : Not stabilized
Shake Reduction : On
SR Half Press Time : 0.20 sec
SR Focal Length : 28mm
Shutter Count : 317
Black Point : 0 0 0 0
White Point : 13568 8192 8192 9248
Picture Mode 2 : Program AE
ISO Floor : 100
Drive Mode 2 : Single-frame
Exposure Bracket Step Size : 0.5
Bracket Shot Number : n/a
Raw And Jpg Recording : RAW (DNG, Best)
Jpg Recorded Pixels : 10 MP
Sv ISO Setting : 100
Base Exposure Compensation : 0
AE Exposure Time : 1/313
AE Aperture : 8.0
AE ISO : 100
AE Xv : 0
AEB Xv : 0
AE Flash Tv : 1/3862
AE Program Mode : M, P or TAv
Lens Codes : 28 94 32 e1 82 66 ed 41 b4 89 98 5f 01 43 6b 03
Flash Status : 0
Flash Mode Code : Off (240)
External Flash Mode : 63
Internal Flash Magni : 68
TTL DA A Up : 0
TTL DA A Down : 0
TTL DA B Up : 0
TTL DA B Down : 0
AE Metering Segments : 12.8 13.4 14.9 14.8 15.0 14.4 13.1 12.9 13.5 13.5 12.9 13.2 13.5 13.5 15.0 13.8
WB RGGB Levels Daylight : 13600 8192 8192 8765
WB RGGB Levels Shade : 16128 8192 8192 6635
WB RGGB Levels Cloudy : 14560 8192 8192 7782
WB RGGB Levels Tungsten : 8192 8192 8192 20971
WB RGGB Levels Fluorescent D : 17376 8192 8192 8847
WB RGGB Levels Fluorescent N : 14528 8192 8192 10076
WB RGGB Levels Fluorescent W : 13088 8192 8192 12206
WB RGGB Levels Flash : 13632 8192 8192 8601
Manufacture Date : 2007:09:22
Model Revision : 2.6
Internal Serial Number : 4347317
Battery Type : 0 2
Battery States : Body Battery Full; Grip Battery Missing
Battery AD Body No Load : 180 (7.9V, 71%)
Battery AD Body Load : 176 (7.7V, 70%)
Battery AD Grip No Load : 5
Battery AD Grip Load : 1
AF Predictor : 0
AF Defocus : 0
AF Integration Time : 0 ms
AF Points In Focus : Top, Center
WB Shift BA : 0
WB Shift GM : 0
Calibration Illuminant 1 : Standard Light A
Calibration Illuminant 2 : D65
Aperture : 8.0
CFA Pattern : [Red,Green][Green,Blue]
Image Size : 3936x2624
Preview Image : (Binary data 26706 bytes, use -b option to extract)
Scale Factor To 35mm Equivalent : 1.5
Shutter Speed : 1/350
Circle Of Confusion : 0.020 mm
Field Of View : 46.4 deg
Focal Length : 28.0mm (35mm equivalent: 42.0mm)
Hyperfocal Distance : 4.89 m
Light Value : 14.5
01-07-2008, 05:01 AM   #38
ftpaddict's Avatar
So the K10D has a built-in thermometer...
also
Does anybody know of a free EXIF editor?
I want to protect my negative scans, but I hate watermarking.
01-07-2008, 05:19 AM   #39
fishy's Avatar
QuoteOriginally posted by JrPentax Quote
very cool
Hi JrPentax,
Want to share how you did that? Back when I tried this I had to search around for tables containing text belonging to the codes that were in the EXIF file... Big mess and lots of un-documented entries.
Enough info on the 'other two' but very little on the PK10D (this was dec 06)
So if you have an AppleScript or whatever you used to get this info, and you're willing to share, please do!
TIA!
01-07-2008, 07:51 AM   #40
PDL
the exif thread in post processing
QuoteOriginally posted by ftpaddict Quote
also
First EXIF editors - please refer to:
https://www.pentaxforums.com/forums/post-processing-software/17819-exif.html
As for the thermometer - yes, the temp of the sensor is important to know. I have read (but can not find the reference) that the Canon 40D was having issues with live view - such that the LCD would go blank as the sensor overheated. Now, not only do we have to deal with small screens - we are going to have to deal with water cooled cameras. Good Grief - the D3 body is 3lbs by itself - add in another for fast glass, add a few more for water cooling and you will have to hire a Sherpa.
The Elitist - formerly known as PDL - Ahh - got a little off track there - sorry
01-07-2008, 09:14 AM   #41
ftpaddict's Avatar
Thank you for the link, PDL.
QuoteOriginally posted by PDL Quote
Kind of like our forefathers, with a tent and emulsions with a tent and emulsions on a donkey, at all times. Back to the fun fun roots of photography.
01-08-2008, 05:55 AM   #42
hey fishy - very sorry - i thought i posted the details on what i did... but i didnt - my appoligies - i used the PERL script exiftool http://www.sno.phy.queensu.ca/~phil/exiftool/ExifTool-7.08.dmg to get the actual data out of the image file... i am hopeing to get a few minets on my computer away from my camera to actually write a nice front-end for the script as its wonderfull but i see sooooo much potential for it... if you would like to email me via my profile here i would love to work with someone who has a bit more idea of what they want out of it then i do..
i have SOME of the programing background to be able to bring something together... and it sure would be an intresting taks, i have often found that writing something like that helps to really learn and understand what is happening and what i am doing...
01-08-2008, 07:48 AM   #43
fishy's Avatar
Hey JrPentax,
Thanks for the post, I'll go and play when I have a minute.
What I wanted to do back then was write my own photo archive DB, where I could store and find images based on keywords and settings. That need has mostly been filled by Lightroom now.
What I still want to be able to do is see the EXIF data Lightroom doesn't give me. Maybe one day a publishing tool.. Not sure. One nice idea might still be an index (MySQL?) of interesting EXIF settings to see what I do most.. So my current interest is purely play (and a bit of frustration maybe)
01-08-2008, 04:12 PM   #44
good luck fishy
do you know if there is a demo of lightroom someplace - i can have a look at the API and see if i can write a simple plugin where you can apple-shift-click on the picture and select exif-data from the popup menu and then have the full data in there... btw - anyone else intrested in such features for lightroom the API is @ Adobe Labs - Adobe Photoshop Lightroom 1.3 Export SDK
it might be easire to NOT use the lightroom api and just write a script for the scriptmenu that does it...
those intrested the lightroom trial can be downlaoded @ http://www.adobe.com/go/trylightroom
i will have a look at it all on the weekend IF i can drag myself away from the camera long enough
cheers
01-09-2008, 01:41 PM   #45
ChipB's Avatar
Downloaded and installed PhotoME yesterday - very nice!! Thanks for all the effort!
BUT, a couple of surprises - seems my *ist DS has a thermometer???? (Wow, who knew???!!!) and I've had almost 14000 shutter releases . (Note to self - don't use continuous mode when taking pics of the grandkids, or the dogs for that matter!! )
Again, thanks for all the work - it's a neat program!!!!
ae, data, exposure, flash, image, lv, mode, pentax, photography, photoshop, segment, time
EXIF data - how to see it please? Nass Pentax DSLR Discussion 7 09-04-2009 05:10 PM
PhotoME shows EXIF but PPG says it is missing? MrApollinax Digital Processing, Software, and Printing 3 07-01-2009 09:12 AM
Name in exif data Mikk Pentax DSLR Discussion 4 12-07-2008 10:22 PM
EXIF Data deludel Pentax DSLR Discussion 3 11-13-2008 11:15 AM
EXIF data Camera lucida Photographic Technique 26 10-10-2008 11:47 PM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
