Originally posted by mand I was not doing anything to the images. Just open in software, convert to jpeg then save
All the jpegs look duller/less vibrant than the original raw unless the jpeg came from the camera.
I wonder why the acr default setting for Pentax K5 don't do the same as the camera setting do, then I would not have to make adjustments to get 'Pentax' look.
Does that make sense?
Mand
With all due respect, perhaps you do not understand the concept of raw capture. When shooting in raw, the camera simply delivers the unadulterated image data to your raw converter. When shooting in jpeg, the camera's on-board computer makes adjustments to brightness, contrast, color saturation etc in a pre-programmed attempt to deliver a pleasing picture requiring little, if any, further adjustment. It is true that most commercially available raw convertors apply some default adjustments, but still, it is generally expected that the user will want to fine tune the image to his/her own taste. The advantage to shooting raw is that all of the original image data is preserved throughout the raw editing process. In contrast, the in-camera jpeg is produced at the expense of discarding much of that data.
In summary, you should not expect out of the camera raw images to look quite as good as jpegs, but the potential for optimizing them is much greater, because of the wider latitude for digital adjustments. It also helps if your raw convertor has a decent color profile for the camera you are using.
Rob
