Defining Pentax-Specific Tags in Exiftool
Has anyone defined names for Pentax-specific tags in Exiftool?
If I want to see if a picture was shot with FineSharpness, I can use the -v option on the command line, and then search the output for 0x0070, But, what I would really like to do is use -FineSharpness on the command line, like with the more common tags.
I tried adding the following to .ExifTool_config:
%Image::ExifTool::UserDefined = (
# All EXIF tags are added to the Main table, and WriteGroup is used to
# specify where the tag is written (default is ExifIFD if not specified):
'Image::ExifTool::Exif::Main' => {
0x0070 => {
Name => 'FineSharpness',
Writeable => 'int8u[n]',
WriteGroup => 'IFD0',
# add more user-defined EXIF tags here...
But - this does not seem to work. Does anyone have suggestions?
