I am about to start editing photos, and using Lr (4) for the first time. Hence I have a plethora of questions regarding JPEGs and Lr 4. I apologize beforehand for the obscene length and possibly bad English.
I currently shoot RAW, but I have thousands of JPEGs. I would like to avoid losing the quality of those JPEGs (through resaving and recompressing needlessly), and be able to handle and edit them as efficiently as possible.
Could you please confirm or correct the following assumptions:
1. Lightroom 4 only resaves and recompresses JPEGs when you export them. Therefore, there are no losses to the quality no matter how much and how many times you edit them (either in Develop module or by altering metadata by adding keywords etc.) before exporting. Furthermore, the exported file is a copy and the original is left untouched, so you can keep working on the lossless photo in Lr.
2. Saving metadata (by saving manually or having the "Automatically write changes into XMP" -option on) to the XMP-space inside the JPEG file does not cause a resave and recompression of the JPEG in a way that would result in any loss of quality (it only modifies the non-image part of the file).
3. Point number 2 holds true even if you choose to include develop settings in the metadata by turning on "Include Develop settings in metadata inside JPEG, TIFF, and PSD files".
4. Saving metadata to the JPEG alters modified date as shown in Finder. There is no setting or convenient way to avoid this.
5. "Automatically write changes into XMP" and "Include Develop settings in metadata inside JPEG, TIFF, and PSD files" should be turned off, unless you also intend to edit those files in another program that understands the data (e.g. another copy of Lr, Photoshop, Bridge etc.).
6. Original JPEGs can be exported without recompressing and loss of quality by choosing to export as originals. In this case, no edits (white balance etc.) will be visible, but changes in metadata will be present (only) if the metadata has been saved in the JPEG as described in points 2 and 3.
7. JPEG files can be renamed on import or at a later point without recompression or loss of quality (even though this information is not only stored in Lr catalogue since the name is also changed in Finder etc.).
8. There are no advantages to converting a JPEG to a lossless format (e.g. DNG) if you plan on editing them only in Lr and then exporting the final versions.
9. Lens profiles only work on RAW images. However, you can alter the lens profiles to make them fully applicable to JPEGs as well. All you need to do is change "True" to "False" in the following line of the XMP file: [stCamera:CameraRawProfile] True [/stCamera:CameraRawProfile]
10. The JPEG file should never be resaved again as JPEG, but in Lr this is not even possible without exporting.
11. Creating virtual copies, moving between folders etc. doesn't cause recompression or loss of quality.
And a couple of additional questions:
A. Are there any (other) settings or practices I should be aware of or avoid in order to avoid losing JPEG quality?
B. Should the workflow with JPEGs differ in someway from RAW workflow in order to achieve maximum quality / efficiency.
C. Are there separate editing presets for JPEGs and RAWs? If so, can RAW presets be applied to JPEGs as long as the resulting look is pleasing?
D. Where could I find good JPEG lens profiles (for Pentax K-5 or Olympus XZ-1), free JPEG editing presets, and Lr tutorials on JPEG editing, such as how much you can tweak certain settings without going overboard etc.?
Thank you in advance!
