Originally posted by Bud A co-worker has asked if I might be able to help her work a little "magic" on the attached scanned photo of her parents. I have to admit that I have VERY limited PP skills and the software I'm using is PSE 5.
My question is this... Do I have the capability with PSE 5 to improve this pic and, if so, can you please give me some pointers. The colors are pretty washed out, but if I could get some of the skin tones and contrast corrected, I think that she might be able to get a decent print for framing.
Thanks!!
Bud
I guess you can do it in PSE5 but I'm playing with CS3 at the moment so I used that.
What I did was :
1. Added a levels layer mask and set the white and black point (to remove the yellow cast as told above).
2. did some spot removal with the "spot healing brush"
3. converted the image to LAB mode and use the "no brainer" curve to add some contrast and to pump up the color (the LAB stuff was from a lesson on Kelby Training on LAB that I saw a few days ago and it works fairly well for some photo's. I think you can find some more information if you google on Canyon and LAB color mode, this is mostly used for Canyon shots at least the tutor from kelby training told this).
4. did some more spot-removal, noise-reduction, and some other minor tweaks.
5. Finally I copied the background layer (flattened the image first) and then used the "Multiply" mode so the overal image got darker.
hope you like the result.
I actually asked a similar question on the NAPP forums a few days ago (had an old photo of my grandmothers house that was really discolored and bad looking).
The advise those people gave was :
1. Get the book by Katrin Eismann, the "Photoshop Diva". She's an authority when it comes to image restoration. I ordered the 3rd edition a few days ago (the 3rd edition deals with CS2 but I guess it also applies to CS3 and there is no CS3 edition yet).
I don't expect you to buy it though, since you might not be willing to do this on a regular basis, I decided to get it because I've got a bunch of old photo's I want to restore so it might justify getting the book in my situation.
2. Make sure you start from the BEST POSSIBLE scan !. What they advised was getting 1 of 2 Scanner programs. 1 of them was VueScan (the other was SilverScan or someting I think) because they can do some color-correction when scanning so you can remove some color casts when scanning.
Anyways, this is just the opinion of some of the people on the NAPP forums that replied to my thread there and I thought it might be valuable here aswell.
Also, from what I've been reading Photoshop is ALL you need to do this, so no plug-ins needed because Photoshop does it all.
