Originally posted by rawr Too many variables:
- bad card write (from camera memory to card)
- bad card handling (eg electrostatic charge from hand to card on card removal)
- bad card filesystem (eg file allocation table damaged, bad sectors etc)
- bad card contacts (eg crud or oxidation of card contacts)
- bad card condition (eg card physically damaged by heat or bending)
- bad card reader (crud or oxidation or rust inside card reader)
- bad USB cable from card reader to PC
- bad USB cable contact/seating from card reader to PC
- bad HDD disk write upon transfer to PC due to device contention, bad sectors etc
- bad PC RAM
- corruption of DNG file by software
etc etc
My bet would be the external card reader though. I had a good Sandisk one fail for no reason and it caused similar problems. Re-formatting your SD card(s) in camera would also probably be a good idea now to avoid any possible SD card file system corruption issues being responsible for the problem.
Thank you RAWR !
Sure looks like all kinds of things can go wrong indeed.
I would agree that this may be from file system corruption (SD card) ... what makes me lean toward this is the fact that I haven't formatted the SD card from within the camera for a very, very long time !
However, althought his may not be the cause, I remember having checked the files in the card, using PDCU, so I could see them all before uploading to the comp.
But, I don't remember if I did look at them all !! ... shows you how good my memory is.
I have, as I explained above in my second post, used that same setup this afternoon and all went well.
For what it's worth, here is my workflow when I transfer files from the camera to the comp.:
1. take card out of the camera and insert into the card reader (Lexar ... rather old: 3 years)
2. connect card reader to the USB; I have a USB cable running from the back of the computer then into the card reader. I did in the past used a direct connect from a USB port but that was really a pain in the butt.
3. computer reads the card and I open the folder ... look at the files (images) in PDCU and after that, I COPY/PASTE to an external HDD. I was told to go that way rather that just drag/drop to the folder as this may sometimes cause some irrgularities. True?
4. click on a small icon on the desktop to allow for "the (whatever device) can now be safely removed ... "
I suppose it would be time to get a new card reader ? Is 3 years too old or asking for trouble ?
I also ought to clean the contacts of the USB cabling/connections ... which I procrastinate doing.
Of course, at not the least, format the SD card in-camera, something I have neglected doing.
I appreciate your input.
Cheers.
JP
