Originally posted by baro-nite Should be reduced all the way to zero. There's no new information to be gained this way.
This is true. I did use the wavelets to sharpen the image, but aside from that there was a SMALL improvement in visible resolution. Not sure if it was more of a trick of the eyes, or if it was because I was playing with 8 MP JPG images from my Mother-in-laws Canon ultra zoom P&S. Mathematically you are correct though...
Originally posted by philbaum Thats where my interest lies as well. Whereas the usual software gets rid of noise by identifying and smearing it, this method, i think, gets rid of it by averaging the results.
I wonder if this would get rid of motion, like some moving grass or bush or tree in a landscape scene. Even if one has a high resolution lens, it would seem that this method might allow even more refinement for improved enlargement???
I assume one can muck about with it and wouldn't necessarily have to use 20 shots. All the top Pentax dslrs have a 9 shot multiple image menu choice but i don't think its exactly equivalent to this software.
Thanks for the discussion!
This does also work for noise. I also took a 5 shot sample of the Orion Nebula to see what kind of results I could get. With a 300mm lens and no tracking, I was limited to a mere 1.3s per exposure to eliminate star trails. Needless to say, that wasnt nearly enough time for my K10, however, I did get enough of an exposuse to see a faint "cloud" in the image. Unfortunately, the rest of the image looked like a explosion of colored confetti from all the chroma noise. I ran the 5 image through and eliminated the noise to less than 10% of what it was, and improved the image substantially! The image was still not worth a grain of salt, but at the time I wasnt trying to get that...I was merely testing the program to see how successful it could be.
You wouldnt need 20 shots in order to stack using Registax, however, the more images you work with, the more resolution/dynamic range you can create in your image, and the better the noise reduction. There will always be a point of diminishing returns, but that will vary on the image, and the needs of the photographer. Ive also been told that working with different exposure times (and thusly ISOs/f-stops) will also improve things - ie - for a wide angle landscape of the sky at night, stack 10 at ISO 100 at 30 sec, plus 10 at ISO 400 at 8 sec, plus 10 at ISO 1600 at 2 sec, etc (values just pulled out of my head).
