Originally posted by robert I've noticed some of my raw files that I export from lightroom are very small after exporting. I can export 2 ,9 meg raw files as a high quality jpg and when I open them one will be 4 megs and one will be 1.6 megs. Both files have the same pixel count and same size on ram but the disc size is one 4 megs one 1.7 megs which seems pretty small to me Bob
The JPG compression quality setting sets a parameter in the compression algorithm, not the terminal file size. If the image has little detail or is smooth (like a single-coloured surface) it will compress well and give a small file. Noise in particular does not compress well.
EDIT:
Just looked up your profile. You have one beautiful daughter, man
