Originally posted by krp I had been wanting to upgrade my monitor for awhile, and last week I found a good deal on a Dell S2240M. So far the color seems a lot better (IPS) and I like the wide viewing angle. The full HD is also nice since it makes the screen feel less cluttered in Photoshop and other programs. But I know I still need to calibrate the monitor, something I've never done before. Spyder seems to be the most popular calibration system. I was thinking of buying an older version used to save money. Does anyone know if the newer version (4) is significantly better than the older versions? I know they claim it is improved but is it worth the extra money? Whenever I've ordered prints in the past the first thing I notice is the prints are a lot darker than the screen. Will calibrating my monitor fix this problem?
You mentioned "ordering" prints. In that case, it will be hit and miss. The whole process from capture to print needs to be calibrated. In theory, sending a properly prepared file out to a good printer should match if the printshop you are using is doing things properly (big question mark there, even for "professional" printshops). Sending a proof along with the file to be printed is still a really good practice, though. If you have a printer that can produce a good proof, however, chances are you wouldn't be in need of sending out for prints.
I'm not saying you cannot continue to order prints and that you won't be satisfied; you may be very satisfied. It will be hit and/or miss, however. Either way, you do need to calibrate that monitor to even have a snowball's chance. Speaking of which, I am overdue for a calibration myself . . . I'm using a very old Spyder with some free software (
dispcalGUI?Open Source Display Calibration and Characterization powered by Argyll CMS ) which works very well. I've also got a very old Dell (ips) monitor that needs to be retired (badly), and printing on an Epson 13x19 pigment printer. It is, despite not being ideal mostly due to aging equipment, still working very well.
All of that . . . to say . . . I'm confident the older version Spyder will be adequate to meet your needs. Save your money and go with the cheaper option.
