I'm looking for a program where you can switch between panel view and individual view, tweak in both. Copy rotation angles either globally (tripod) or individually (hand-held). Copy crop area & crop frame initial position globally (but allow tweaking of them afterwards).
It's handy to be able to apply a sharpening change profile or different manual sharpening per image in a some sequences. For example, in the high jump, I use MF and 10x LV to accurately focus a Pentax-M 50/f1.7, on a tripod, on the horizontal bar itself. (I've used AF lenses for high jump too, but they often catch on a background object, so the jumper sometimes is OOF). Although I've used f/5.6 aperture to allow some DOF, the jump take-off in front of the bar, over the bar, coming down the other side, landing, are all at sightly different focusing distances. So I also apply sightly different sharpening in each image in SP4. Since the camera position and bar are a fixed difference apart, the take-off, top of bar, coming down the other side shots are at reasonably constant distances too, so a sharpening change profile would be handy when you dealing with processing many jump sequences. Say 4-5 images per sequence, 3 goes per jumper
at each height, 5-40 jumpers per group, male & female and different age groups (I'm photographing at the junior level).
It should be able to automatically group images based on Exif date, with 1-30s (adjustable) difference being considered to belong to the same sequence, but you can easily drag-and drop if it gets it wrong. There is a HDR program, FDRTools, that operates that way and it can be a big time saver.
http://fdrtools.com/eng/manual/fdrtools_2.6/nav/tutorial_iv.htm
You would think with the burst capabilities of modern DSLRs, someone would have created a program that assists with the panel/sequence composition & layout process.
Dan.
