Originally posted by thechumpen I recently printed one of my pictures to my small photo printer and the image was really dark compared to how it looked in Lightroom 4. I researched and discovered the whole topic of monitor calibration.
I have an NEX 2470WVX that I bought before I got interested in photography. I have used the monitor calibration tool built into Windows 8 (
Calibrate your display) and the problem I have is that the test screens look completely different depending on my vertical angle of viewing. E.g. if you look at the gamma test in the link then this looks completely different depending on whether I hunch down in my chair or sit up.
This makes me think I am on a losing battle with this monitor. Even if I buy a calibration solution it is always going to look different depending on my viewing angle.
My question - is this the same for all monitors or is mine just no good for photo editing etc? Can anyone recommend a 24" monitor that is more suitable?
One key concept missing from this discussion is
colour management. Colour management is the framework that controls how images are rendered throughout the processing chain from camera to monitor to printer.
Fortunately or unfortunately, it is necessary to have a basic understanding of colour management in order to have any control over how your images look, particularly when printed. If you understand colour management, you will understand how and why monitors and printers are calibrated. It's all about profiles.
Monitor calibration is an important part of colour management. So is colour managed workflow when printing. Lightroom has good capabilities in that regard, so I suggest that you seek relevant online Lightroom tutorials or books.
In a very quick search I found a decent-looking tutorial about colour management. It's a few years old, so some hardware specifics may be outdated, but I would say the underllying ideas are laid out pretty well:
Color Management Primer: Overview - photo.net. Any good book about photo editing should also have a clear explanation of colour management.
With regard to your monitor, I can't comment on that particular model. If you are having problems with viewing angle, I suggest that you go to a computer store and simply move up and down in front of several monitors to see how they compare to the one you have. Maybe yours is not as uniquely bad as you think! Of course, getting an IPS monitor is an option.
A monitor calibration device is very useful. I use a Spyder 4. I find that it givers very accurate colour balance on my system. I tweak gamma manually to suit my tastes in terms of brightness/contrast. One individual in this discussion dissed the Spyder device and recommended something else, but offered no reasons. I suggest you look into reviews yourself.
There are a couple of other pieces of advice in this discussion that I consider to be dubious.
One is to only use sRGB colour space. Adobe RGB is a larger space that is still very safe for general use, and is something of a standard. Most experts would recommend using Adobe RGB or even one of the larger colour spaces for serious work. I use Adobe RGB based on my personal testing. The reasons for using larger colour spaces are a bit complex, and often subject to debate when you get into spaces larger than Adobe RGB. Again, look into it yourself and do a bit of testing.
Another suggestion was to use "Print Fix", which is an automated adjustment function in some printer drivers. That can work in some cases, but in fact all you're doing is blowing up image corrections that you may have made yourself. It's not all that different from selecting automated image adjustment in Lightroom. No point in doing colour management if you go that route.
Hope you find this useful.
