Originally posted by graphicgr8s Once you have them highlighted you can just drag and drop if you want to move them.
Hi
That is very true. But I find it works best (for me at least) if it is only one or two files you want to shift. If you have 40 or fifty or even 200 hundred I find it easier to highlight them all by left clicking just next to the left ot right side of the first file, hold the left click button of the mouse and then start moving the cursor down to the bottom past the border of the file window until you reach the end and all files are highlighted. Then let go of the mouse button and click the right mouse button, a window will fly out giving you several options. Choose copy, then go to your new new folder and paste them there.
If you only want to shift certain files out of lots of others (if you know which ones they are and then it works better if you go back from detail file view to to icon view) you can also select a whole bunch of them by holding down the "ctrl" hey and click over every file you want to select. If you find you have highlighted the wrong file then just click this file again (still holding the left mouse button) and it will de- select this particular file. After that proceed as above.
In Windows you can skin a cat many different ways.
Greetings
