03-01-2008, 08:01 PM   #1
Ole's Avatar
ACR Camera Profile, where do they come from?
Adobe Camera Raw (mine is version 4.3) has two profiles, ACR 3.7 and Pentax 1.00. The latter appears to give more saturation.
Where do these profiles stem from? Is the Pentax 1.00 profile fine tuned to Pentax, and ACR 3.7 just a general profile? Can anybody shed some light on this?
What do you use?
03-01-2008, 08:17 PM   #2
deejjjaaaa's Avatar
may be this is the answer from the man himself (from Adobe forums - ACR section) :
Thomas Knoll - 5:49am Apr 20, 07 PST
Basil:
I answered our question. Rejecting the answer without even trying it is not going to solve your problem.
The problem is Pentax shipped the K10D with firmware that embedded a buggy embedded profile in the DNG. This embedded profile had the mapping between temperature/tint values and image colors way way off. (Pentax did the math wrong when they created the profile).
When I added official support the K10D in Camera Raw 3.7, I created a much better profile that has correct mapping between temperature/tint values. I made this the new default profile. I made the old (buggy) Pentax profile also available in the camera profile popup.
Unfortunately, when reading DNG files with existing settings created before 3.7, I did not correctly map settings to use the old profile, and it is using the new profile by mistake. This is the cause difference in colors you are complaining about.
To fix this, just pick in old profile from the Camera Profile popup. You can do this on muliple files at once using the filmstrip mode of Camera Raw (open all the files into Camera Raw, select all the files, and change the popup, and press done).
We try to avoid this kind of stuff happening. Sometimes we make a mistake (called bugs). This is one of those cases. In this case the bug was specific to Pentax K10D DNG files with settings adjusted before the camera was officially supported by 3.7.
The workaround (picking the old profile from the Camera Profile popup) is quite easy and fast. I suggest you just try it rather than just ignoring my answer.
03-02-2008, 12:16 PM   #3
Ole
Ole's Avatar
Thanks! I guess the answer then is to stick to the ACR 3.7 profile and leave the Pentax 1.00 profile alone.
03-02-2008, 04:33 PM   #4
deejjjaaaa's Avatar
QuoteOriginally posted by Ole Quote
and it was recently reported that "oops, I did it again" (c) Brit... , sorry - Pentax
QuoteOriginally posted by topic : ACR update for Pentax K20d:
Thomas Knoll
- 10:56am Mar 2, 08 PST
Pentax is made a math error when they computed the camera profile they embed in DNGs. The colors look OK, but the temperature/tint numbers are way off.
so brace yourself for "Pentax 2.0" profile
PS: now if the same people (in Pentax) are writing the code for their AF
03-02-2008, 09:06 PM   #5
Ole I am not sure this is right. I think that the Pentax 1.0 profile is the official Pentax Profile for ACR 4.3.1. I have been using it as I want the files to respond to how Pentax has set up the algorithms.
Thomas Knoll himself an Adobe programmer admits making mistakes in correctly mapping settings in ACR 3.7 for the K10D in what is posted in the statement supplied by deejjjaaaa. Even though Knoll admits creating bugs he is blaming Pentax. Some how that does not sound right.
03-02-2008, 10:04 PM   #6
deejjjaaaa's Avatar
QuoteOriginally posted by Rico Quote
When in Rome, do as the Romans do (c) apparently them, Romans
03-14-2008, 09:54 AM   #7
deejjjaaaa's Avatar
What do you use?
now we have new profile ACR 4.4 for K10D
John Nack on Adobe: Lightroom 1.4, Camera Raw 4.4 now available
Previous camera profiles identified in the Calibrate panel of the Develop module may have displayed poor results at extreme ends of the temperature and tint ranges. A new camera profile identified as Camera Raw 4.4 is now available and will be applied by default to all images without existing Camera Raw or Lightroom settings. The creation of new default profiles will also include the updated Camera Raw 4.4 profile. Images edited in Camera Raw or Lightroom with earlier profiles will retain the earlier profile value and visual appearance.
acr, camera, pentax, photography, photoshop, profile, profiles
Pentax K-x camera calibration profile (ACR & Lightroom) switters Digital Processing, Software, and Printing 4 03-01-2010 12:47 PM
ACR Camera calibration script in PS experience? gsrokmix Digital Processing, Software, and Printing 0 01-31-2010 10:33 AM
good K10D profile for ACR - please help! huqedato Digital Processing, Software, and Printing 3 01-08-2010 12:38 AM
Camera Calibration / Camera Profile Setting for K200D in ACR? LensScribe Digital Processing, Software, and Printing 3 07-23-2009 07:21 AM
Batch converting camera dng to acr dng using acr Maynerd Digital Processing, Software, and Printing 6 01-17-2009 02:22 PM
All times are GMT -7. The time now is 08:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
