I do not have X5, but X4. As X5 didn't offer anything subtantial better over X4 I didn't upgrade when it cam eout.. But I do like X4, I needed to get used to it after using PSE. But now I know how to work with it, it isn't that much different from PSE. But both have their cons and pro's. The biggest con of PSE I found that after opening a RAW file, you couldn't use layers, had to convert it to a 8bit tiff file. X4 does that (don't know if PSE 11 can do it now, only used up to 9, then switched over the PSP). The biggest con of PSP is the raw converter. basicly, it kinda sucks. But for me it not a problem, casue I sue also lightroom, and will go from there to PSP if needed. They do have an adjust tab, where you can do all the adjustments needed to develop a raw file. But when going to edit with layers and all, it first needs to be converted into a PSP file. Which is anoying, as you need to delete it later. Would be better if you could just go from adjust to edit in one go without the need to save first.
PSP has a rather nice HDR feature, I have heard it is even nicer on X5 as you can also do single photo HDR with it.
So I personally like it better than PSE, apart from the raw developer, but for that you can use the adjust tab.
