04-11-2013, 06:40 AM   #1
hard drive not backed up..
my hard drive crashed which like a dope i didn't have it backed up, so i lost all my photos.. my question is can i get copy's of the photos i have posted without removing them from the users photo gallery?? or can i download them and then re-post them back in the gallery? thanx!
04-11-2013, 07:57 AM   #2
Kozlok's Avatar
There is recovery software that can find your files as long as you don't over write them with something else first.
04-11-2013, 08:29 AM   #3
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by Kozlok Quote
.... If the hard drive is operable. I suspect, from his use of the term "crashed", that probably isn't the case here.
I'm sure Adam will be along directly to answer your question.
04-11-2013, 08:53 AM   #4
thoughton's Avatar
Just make sure you don't throw the hard drive away. Depending on how precious your photos are to you, you may wish to contact a professional data recovery company. It could be a little expensive (hundreds of dollars) but worth every penny if the photos are irreplaceable.
Re-downloading your photos from here will result in low-resolution versions of your originals.
04-11-2013, 11:12 AM   #5
Jacquot's Avatar
Yep, happened with my wife's computer. We were able to recover almost everything, but it did cost hundreds, even in NYC! I have good back-up now.
04-11-2013, 11:49 AM   #6
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by Jacquot Quote
When it comes to backing things up, I am a firm believer in redundant redundancy. No files should exist on fewer than three drives, one of the three geographically separated from the working and primary backup drives.
04-11-2013, 01:54 PM   #7
the only problem there is i can't even log on even with all the options from the start menu', won't read the install disc or a flash drive with the recovery console on it. thanx
04-11-2013, 01:57 PM   #8
QuoteOriginally posted by Parallax Quote
you are a 1000% rite. it's another lesson learned the hard way, which seems to be the way i learn all my lessons.thanx for the words of wisdom..
04-11-2013, 02:05 PM   #9
QuoteOriginally posted by thoughton Quote
thanx mr. thoughton. that figures the resolution would be poor. if it wasn't for bad luck i would have no luck at all..
04-11-2013, 02:11 PM   #10
yep mr. jac. you can bet your britches it won't happen to me again.
04-11-2013, 02:28 PM   #11
PEG Moderator
Kerrowdown's Avatar
These are good words of wisdom, heed them well, fellow forum members.
04-11-2013, 02:31 PM   #12
crewl1's Avatar
Get your self a USB housing for your drive.
Install it in the housing, then connect it to another machine or laptop.
See if you can find the directories that contain the image files that way.and copy them off.
04-11-2013, 02:34 PM   #13
Lowell Goudge's Avatar
This is great advise but too late, I do the same however
QuoteOriginally posted by elmo wartz Quote
Get a new drive or computer and a USB case for the crashed drive, chances are you have damaged the boot sector and perhaps the operating system files but. Not the data section. Depends on how the disk was set up of course, but OS and program files a usually the most vulnerable.
04-11-2013, 03:37 PM   #14
Tom S.'s Avatar
Although it's probably your hard drive, it could also be a couple other things like the cable or the controller. If you can. try putting it in another computer and see if it can read it. By any chance is it a WD hard drive? Just curious because I had three of them fail within a few months of each other. There are data recovery services, but they aren't cheap - anywhere from a couple hundred dollars and up. They wanted $450 to salvage one of mine.
04-11-2013, 05:10 PM   #15
I would take it to a tech. While you maybe able to write from the drive using another computer, you can also damage files from spinning it if there is mechanical damage. Most of the time data is recoverable.
drive, photography, photoshop
Nature Still Cleaning up the Hard Drive 3 wildman Post Your Photos! 9 08-07-2011 12:38 AM
Nature Still Cleaning up the Hard Drive 5 wildman Post Your Photos! 2 08-06-2011 11:28 AM
Nature Still Cleaning up the Hard Drive 2 wildman Post Your Photos! 4 08-02-2011 03:21 AM
Nature Still Cleaning up the Hard Drive wildman Post Your Photos! 2 08-01-2011 12:04 PM
Help! My external hard drive is not 'acting' up! schmikey Pentax Camera and Field Accessories 1 04-09-2010 08:58 AM
All times are GMT -7. The time now is 02:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
