Originally posted by grhazelton Some day's images refused to load, others dropped varying numbers of images. I'm using the file menu's Export as Catalog. Those images which do make the trip have lost their tags, etc.
Questions:
1. When you say refused to load, what do you mean? Load into Lightroom as an imported catalog?
2. When you exported images as a catalog, did you select all the images in the library that you wanted to export?
3. When you exported images as a catalog, did you check the Export Negative Files box (by negative files they really mean master image files)?
4. In your exported catalog folder (on your desktop), what files are contained? The previews.Irdata and the catalog.Ircat and the .xmp sidecar files and the image files should be there.
M
