Originally posted by haycyn What is the consensus on the best way to store the photos? Rotate 2 external hard drives?
1. There is no consensus
2. Accept the fact that whatever you do some data will probably be lost no matter what you do either through gear failure or operator error.
3. The most you can do is come up with a system that best meets your needs and is also practical with respect to time and money but will not be perfect.
For myself I use two external drives one is database A and the other B.
Database A is the active one where I add, delete, rename, change the file structure etc and then when done with A mirror it over to database B so I end up with two ongoing, running identical redundant independent databases.
Because I do the mirroring about once a week I have the advantage of watching for any errors in the transfer that might alert me that one of the drives may be getting flaky
Finally, perhaps once a year, I select a limited amount of files that I particularly value and burn two sets of DVDs for a bit more safety. At this point, in my case, this only involves 4 disks - two identical 2 disk sets.
Done.
