Originally posted by Watson I do all my processing on Aperture on a Macbook Pro. I sometimes use Lightroom as well but usually just Aperature. I don't have to do much with the images actually, except adjust the sharpness sometimes in the raw adjustment drop down, sometimes boost the definition and rarely the saturation of the colours or vibrancy. I almost always adjust the brightness and contrast as well as highlights and shadows. On the printer I have dome a preset with the highest dps (slowest printing) and use high gloss pro paper.
Thanks, for you prompt reply. I'm not surprised you are not too happy with your printer's output, but it is up to you to feed it better data.
A few thoughts:
1. Because you didn't mention anything about monitor calibration or color management, I assume you don't actively pursue this practice. This essentially leaves to chance matters of color accuracy for both evaluation and output. I'd suggest you read up on the subject, spend the money on a good IPS monitor and hardware calibration tools. This will make your printer perform to your expectations as the input will be exponentially better.
Do realize that laptops-- even a good one like yours--generally have monitors inferior due to angle of view issues.
2. Choose either Lightroom or Aperture. I cannot fathom using both. They each impose a different, though excellent, workflow.
3. Learn about digital sharpening techniques. Get Fraser & Schewe's book and practice the three-phase approach to sharpening. All RAW files require fairly significant sharpening. Your prints will look much better.
Hope this helps.
M
