07-27-2013, 02:54 AM - 3 Likes   #1
GUB's Avatar
Slow colour curves in gimp on linux
The curves tool on my Gimp (2.6 on Ubuntu) have gotten progressively slower to open , more than 5 seconds. It has taken me a lot of searching to find the solution so I thought I might share it with you in case someone else has the same problem. Turns out gimp curves dutifully saves a copy of your settings every time you use it. This had grown to a 28mb file on my computer and the reading of this was taking the time. Solution: Navigate to Home then Ctrl+H to show hidden folders. Find Gimp2.6 / tool-options and find the file called "gimp-curves-tools. settings". Delete this file (Just rename it if you are nervous about deleting it) It creates a new file when you restart the computer. All fixed.
07-27-2013, 09:40 AM   #2
Seems it's true for Gimp 2.8.2 as well, although I haven't noticed a slow-down. Obviously, I'm not photographing enough.
Thanks for the information.
07-27-2013, 11:56 AM   #3
Thank you very much. It made my curves tool quicker too.
One small thing to be aware of, is that it deletes other tool-options too (which can be saved via Edit - Preferences - Tool Options).
The solution is to have gimp open while you delete the settings-file, and then click 'Save Tool Options Now'.
Thanks again for sharing.
07-27-2013, 12:01 PM   #4
Moderator PEG Judges
Kerrowdown's Avatar
That's a great heads up for all the Gimp users out there.
07-30-2013, 07:59 PM   #5
There's also a plugin (well, a script, actually) to clean out the tool settings at each Gimp startup. You can also customize the script (via a config file) to only clear settings that are so many days old or if the list is longer than a specified number. Pretty handy, actually. Info about it here: Keeping the color tools settings under control | GIMP Plugin Registry.
07-30-2013, 10:37 PM   #6
GUB
GUB's Avatar
QuoteOriginally posted by ashurbanipal Quote
Yes I bumped into that one just before I found the blog describing deleting the folder. Figured it was something one had to address only every few months so didn't bother downloading the plugin. Is this a problem in windows installs as well? Or just the linux flavour.
07-31-2013, 04:48 AM   #7
baro-nite's Avatar
Can't speak to the Windows version, but after reading the above I checked the size of these files on my Mac version. Nothing too big.
The main slow-down I've noticed since upgrading from 2.6 to 2.8 is the gradient tool -- bad enough that I never use it (create gradients with blur instead).
07-31-2013, 08:10 PM   #8
I believe Gimp's behavior is the same on Windows, but I'm using it on Kubuntu so couldn't say for sure. I not actually too concerned about the file sizes and never noticed a slowdown on my system. I'm using the script mainly to keep the list of settings tidy. I only really need access to the last 4-5 settings I've used, plus ones I've explicitly saved, and the script takes care of that for me.
computer, curves, file, gimp, photography, photoshop, solution, time
pktether on Linux viper56 Digital Processing, Software, and Printing 5 04-07-2013 04:53 PM
k5 on linux Big Daisy Troubleshooting and Beginner Help 11 01-28-2013 02:24 AM
GIMP 2.6.12 vs. GIMP 2.8.0 Vasyl Digital Processing, Software, and Printing 13 06-19-2012 02:00 PM
Linux help, please - Photoshop plugins in GIMP Wombat Digital Processing, Software, and Printing 4 07-28-2009 10:59 AM
Installing Wavelet Denoise plugin for GIMP under Linux Mann Digital Processing, Software, and Printing 9 07-16-2009 02:34 AM
All times are GMT -7. The time now is 02:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
