Originally posted by Smeggypants Yes I use lots of custom develop presets too that I add at the start of the develop phase, but none of them contain sharpness or Noise reduction ( or CA removal ).
try temporarily turning off sharpness/NR/CA on one of your images and see how much mroe responsive the other sliders are.
If you mean the one listed aboev which requires putting the catalogue on the Ram Drive, then I would enver do that. You ahve to remember to copy teh catalogue back to regular drive at shutdown or if the computer crashes you've lost your work. I do have caches on a RAM Drive though
I have them without that, then I'm stuck with going down to NR (sharpness doesn't bother me), selecting luminance, waiting 5-10 seconds while it pins the CPU, sometimes locking up, sends the fan into warp drive, then I have to do it again for chroma. I have a baseline that I can adjust from.
The suggestion is not helpful because it brings us all back to where we're all starting out from.
Not to mention, when I do concert shots, I have series that are all similarly shot, similar amounts of noise, so I might have 200 shots that I have to simply copy an established adjustment table from one shot across all or most of the rest.
So the advice most are giving so far seems to not take into account workflow, which is the advantage of LR for people that work using photography. It's working counter to efficiency.
