Originally posted by TenZ.NL Hi guys,
Got a question I hope you can answer for me.
I was just going through my holiday shots in LR5 and came across a sequence intended to stich a panorama. They were shot MF and on M to avoid focus- and exposure-issues and they came out fine. The sky was not blown out according to LR. So I selected the sequence, rightclicked on one of the pics and selected "Merge to panorama in PS CS5" (like I allways do). PS started up, did it`s panomagic et voila....a very nice panorama. Except for the fact that 80% of the sky was blown out.
I went back to LR and checked the original DNG`s and allthough the scene had a grey sky and all shots were exposed to the right as much as possible, none of them showed clipping. Recovering highlights of the stitched image didn`t work, big parts were blown out completely. The final image is unusable for me.
The originals are good, so why did it go wrong in PS? Does anyone know what happend here?
TIA and kind regards,
Jacco
Hi there,
I'm using CS6 so I cannot exactly reproduce the issue but I suppose it has to do with the way that Photoshop is blending the individual shots. Something similar can happen in Hugin which I use for stitching but to a much lesser degree. In order to avoid this, I try to keep my white points well clear of the 255 value. It is best to start out with 16bit images and lower the white point by 10 (from 255 to 245) in Image > Adjustments > Curves. Then even when the individual images are processed to fit seamlessly you should not end up with blown highlights. When your panorama is complete you use Curves again to push the highlights where you want them. When all processing is done you can set the mode to 8bit.
