Originally posted by calicojack Lightroom does import and work on jpegs's as well as raw formats, correct? What is your opinion of the photo organizer in Lightroom as opposed to the Elements organizer.
Yes it works with jpegs, DNG, PEF, TIFF and likely some others I don't use.
Lightroom IS an organizer. Lightroom is a photo organizer with processing abilities added on. PhotoShop Elements is an image processor with some rudimentary organizing functions added on. As noted above if you regularly use layers then you will also need a pixel editor like Elements or GIMP or one of the many plugins available, but for 95% of all other work Lightroom is all you need.
Don't expect to just sit down and be comfortable with it though, especially if you have a lot of experience with Photoshop. The workflow is much different. Start slow, learn each section and don't get frustrated. LR is a big program with an amazing range of features.
A few things to keep firmly in mind:
1) The key to LR is presets and templates. Figure out how you want to do something and then create a preset or template for that.
2) LR is an image organizer, your workflow must be centered on it 100%. If you are used to just jumping into Elements for a quick edit and then saving the file and using it somehow, this will change. When you need an image you go to LR and export it in whatever format, and size you need.
3) Your images are not "in" Lightroom. You need an organized file structure on the hard disk where the actual files are located. LR can move the images from your card to that spot for you, but the files are always separate. Having the files in one organized place makes moving to a new computer or just regular backups much easier.
