Originally posted by Bagga_Txips Try Faststone.
Its free, give quick results, and is an excellent first step to prepare you for the complexities of Adobe. In fact I think Adobe products are a bit too complex for most PP situations.
I give this suggestion a BIG endorsement.
Faststone is a great tool for
quickly browsing/culling photos, and doing simple adjustments. It has most of the basic editing functions the average person needs without all the overhead
of something like PSE. In particular, I like the way it uses your whole screen for the image, and all the command menus only appear when you mouse over to the boundaries of the screen. Once
you learn the keyboard shortcuts to your mostly frequently used commands, you don't even have to do that anymore. I think all the editing tools have a button that allows you to see what the image
looks like before the adjustment in question is applied, so you can quickly do a before/after comparison. Yes, there's all kinds of fancy stuff that FastStone can't do, but that's the beauty of it.
With a single keystroke you can send an image to a more sophisticated editor like PSE if you need to do something beyond FastStone's capabilities.
Another of FastStone's strengths is that for browsing RAW files, it uses the embedded JPG previews, so it it's faster than anything else when it comes to bringing up the contents of a folders. Great
for quickly locating images, comparing similar images side by side, etc.
I've got PSE 9, and it has certain tools that I need from time to time, but I find it doesn't do a great job of converting the RAW files from my K200D - sometimes, it doesn't render certain colours "correctly".
I send those RAW images to PDCU, which seems to be better in that respect, though the interface leaves something to be desired.
I've never been a big fan of Lightroom. GIMP is great for graphics, but I just don't see using it for applying adjustments to photos.
Generally, FASTSTONE is my starting point for everything. That's my default photo browser. From there, I launch whatever other program I use. Often, I don't need any other program.
Cheers
---------- Post added 02-11-2014 at 09:28 AM ----------
Originally posted by 45 Mike I don't need a "click this" tutorial, but more of a general discussion of what common problems are encountered and what general solutions are used to solve those.
How to tell if you went too far, what are the rules? When to break them? etc. etc.
This is a tough question to answer, because so much depends on the kind of photography you do. I wish I had the skills that some posters have when it comes to working with RAW files, but
everyone is going to have slightly different problems to tackle, so one person's approach isn't necessarily going to work for someone else who has different photographic challenges.
My K200D was a bit slow at writing to the SD cards, and was prone to having issues with certain cards, so using
RAW+ wasn't a viable option. As a result, I would just shoot RAW. As a result, I've got several years worth of shooting that is strictly in RAW format.
Now, with my K30, I can use RAW+ and to be honest, it's pretty tough to better the JPG generated by the camera with either
Silkypix 3 or PSE 9. I have the RAW files if I need them, but the JPGs are often fine.
I mostly do nature photography, and I find that when I actually
need to resort to tweaking a RAW file, it's due to a problem with either the White Balance, or the Exposure. Maybe I had the camera set
for Daylight WB and a cloud happened by, so the WB is off in a photo. I find the WB presets in most programs are useless, so tweaking WB can be a challenge ( if there's a known gray element in a scene, you can set
WB on that using an eyedropper tool ). PDCU's 5 point gray point setting feature is great for this.
For exposure, maybe there's a particular element in a scene where the highlights were blown out in the JPG, so I go to the RAW file and see how much detail I can recover ( by either easing back the exposure, or using
a highlight recovery tool ). Or maybe there's too much contrast between highlights/shadows on my subject, and I need to even things out a bit by adjusting levels, or curves. You can make those kinds of adjustments on
a JPG file, but RAW gives you far more latitude - there's a lot more information to work with. Often, you have to use a combination of tools to get a satisfactory result. For example, if you fix blown highlights by decreasing
the exposure, you might have to adjust levels so that the image isn't too dark. Once you start playing with multiple adjustments, the shortcomings of JPG start to show themselves as the image degradation accumulates. This is why you do your major adjustments as part of the RAW conversion.
If your original photo looks pretty good straight out of the camera, then you can probably make minor adjustments directly on a JPG image. With RAW, you have a lot more latitude for making adjustments, so if you look
at your original photo and think to yourself "that's gonna take some work", then you probably want to go back to the RAW file and start there. The only way to get to a point where you can make that kind of a call is to practice.
If you practice making simple adjustments to JPG images for a while, you'll become familiar with what the various tools do. Eventually, you'll come across a photo that you just can't "fix". You'll know what it is you want to do, but you won't be able to do it the tools at hand and/or JPG as fodder for them. Then you can try going to the RAW image and you can see if you can "fix" the image using more sophisticated tools.
Another approach might be to deliberately screw up some photos and see if you can fix them in RAW. For example, take a shot of a white flower and blow out the highlights a little. See if you can recover them from the RAW file. Take your camera out on a sunny day, and take the same shot with WB set to "shade" and "sunny". Using the RAW file, see if you can "fix" the shot where you had the WB set incorrectly.
Take a scene with extremes of contrast - expose images for the highlights, and for the shadows. Compare the different exposures, and see if you can make a good "compromise" photo from one of them by either recovering the highlights or the shadows. Try to do this from both the JPG and the RAW files, and compare the results. Challenge yourself to see if you can see how the RAW file gives you additional latitude.
There's a lot more to working with RAW files, and there's certainly lots of folks on this forum who know way more about it than I do, but as far as answering the question of "What does RAW give me that JPG doesn't", I think for most people, it boils down to latitude for adjusting WB and exposure. If you nail those to start with, it's harder to see why you would bother. It's when you screw them up that the advantages of RAW become apparent. So as a learning exercise, you can either try pushing the envelope in your shooting to give you images where you
need to play with the RAW images, or you can deliberately screw up some photos.
Once you get a handle on what you can do when you start with the RAW image, you might be in a better position to start to be creative about it. ( in other words, exploit RAW creatively rather than as a way to fix
shots that you've screwed up )
