02-21-2014, 05:10 PM   #1
chimpwithagun's Avatar
Flash and EXIF
In all my images, the EXIF data says flash:no when I use a hotshoe flash. It doesn't matter if I pop it on top of the camera, connect it via cable, or use wireless triggers. The EXIF says flash:yes if I use the pop-up flash, why not hotshoe?
02-21-2014, 05:16 PM   #2
It can't recognize manual flashes, it should show up for P-TTL hotshoe flashes.
02-21-2014, 09:27 PM   #3
So... Does that mean that every time the shutter clicks the hot shoe gets juice? If I put my finger over the contacts and click can I get shocked?
02-21-2014, 09:46 PM   #4
There is very little power anywhere in the camera's hotshoe and none at all on the center pin that fires the flash. All it does when the shutter fires is pull the center pin to ground, whether it sees a flash there or not. The rest of the pins are for communicating with a P-TTL/TTL flash, just 0-5V signals.
If you happen to have an old flash with a high trigger voltage, not only can you get a shock from the foot, it can damage the camera. Always test old flashes with a multimeter (center pin to ground on the side of the foot) before putting them on the camera, most made with in the last 20 years are fine though.
exif, flash, hotshoe, photography, photoshop
O-GPS1 and your EXIF data - When the GPS is on, it strips data from the EXIF? Sagitta Troubleshooting and Beginner Help 17 11-23-2016 02:25 AM
Image viewer with MF and AF in EXIF? malenisjaj Digital Processing, Software, and Printing 13 02-08-2014 07:49 AM
K-30 and EXIF Zafar Iqbal Troubleshooting and Beginner Help 7 01-12-2013 07:31 PM
Flickr and EXIF Data rayallen Digital Processing, Software, and Printing 28 05-02-2010 09:55 PM
Downsizing and EXIF Jewelltrail Pentax DSLR Discussion 10 07-07-2008 08:01 PM
All times are GMT -7. The time now is 02:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
