Originally posted by stevebrot The banding has little to do with JPEG compression and a lot to do with the 8-bit/channel color limitations of the JPEG format. Normally it is not much of a problem, but with large regions of primary color and a shallow gradient (such as the sky), 256 shades just ain't enough. Gradients appear as discontinuities. As noted above, PP can make the problem worse.
Steve is correct. When you go to JPG, you are going from 12- or 14-bit color in RAW (not sure of your camera) to 8-bit in JPG. Even setting the lowest compression (best spatial resolution) will not alter this fact; JPG is lossy, even if it is only in dynamic range.
Just for fun and to show an extreme case of what you are seeing, try this:
1. Take one of the better images and open to edit in PSPX6.
2. Go to Image->Decrease Color Depth->[Any Lower color depth]
3. In the dialog box, select Nearest Color for the Reduction Method.
The result will show the effect of reducing the dynamic range of the final image--showing banding (also called False Contouring).
[As an aside, our eyes are great at detecting edges, but not so great at perceiving gradients of color.]
If you select Error Diffusion for the Reduction Method, the algorithm will try to smooth the boundaries between levels, albeit not perfectly--still leaving a bit of banding.
Also, the order in which processing is applied can affect the final result. Maybe reducing RAW to 8-bit RGB with Error Diffusion first might give better final results.
Final thought. I have two monitors with differing color quality (even though calibrated with SpyderPro). The lower quality monitor shows a much more pronounced effect of the banding, so your monitor might be exaggerating the banding a little.
JPG, web standards, and monitors all conspire to give us the least common denominator of image presentation.
My two cents. Hope this helps.
Cheers,
Lou
