Ok, ill have another go and see if I can persuade you.
converting a TIFF to Jpeg takes a smoothly rendered image and compresses it, throwing away detail and substituting detail and colours that can be grouped together, referenced where they are and then it keeps a rudimentary number of pixels in the file with references where similar ones exist. That's how lossy compression works.
Then it used this tone map to rebuild the image using the rudimentary pixels and their reference locations. In a very simplistic way, this is what Jpeg lossy compression does. The result is banding, you don't notice it in the jpeg, but its there.
And as soon as you try to post process this banded image, varying the brightness, or colour, or contrast, or saturation, or sharpness, the banding emerges.
If you downsample the source before Jpeg compression, you reduce the number of pixels the Jpeg engine can choose from to represent the detail and you increase the banding and it emerges sooner and more aggressively.
Traditional and current best practice is always always always post process on original files no downsampling is allowed.
This minimises any effects post processing has and renders the smoothest resulting images. No banding emerges when you post process because none exists in the image yet.
At the very end, after post processing is complete and you have your finished unbanded image, then you can downsample and save as a Jpeg. But beware, if you save as a low quality Jpeg you will create obvious banding due to this and this alone. Save as a high quality Jpeg not low.
The filesize you end up with is no larger than if you had downsampled first, and its no harder to do, so theres no problem doing it this better way. You just get a better result.
It wont cost you anything, it wont take longer, it wont be harder, it wont leave you with larger files, it is the recommended way, and all you have to do is try it.
I don't accept your argument that im advocating some unproven exotic method like your audio example, this isn't something that im proclaiming that you won't see the point to.
You claim that this method is ok for me but you have different requirements, well my requirements are images without bands in them, how are your requirements different to mine.
You are seeing images that have problems you cannot accept. You will either see an improvement if you do it my way or you wont. And if you see an improvement youll know I was right. If you don't youll know I wasn't right.
And my way isn't something ive come up with, its been the recommended standard way to process images for nearly 15 years. Your way is the unusual way. What they say is, if you downsample and save as a Jpeg and then post process, banding will emerge. Isnt that what your seeing.
So how about it, cant you spend 15 minutes trying the industry standard way for once. ---------- Post added 04-03-14 at 08:13 AM ---------- Ok, ill have another go and see if I can persuade you.
