Evening,
About 6 months ago I took some shots of some antique cars at the Model T Factory in downtown Detroit. The backlighting from the windows was pretty bad, and I bracketed all the shots with 5 frames +/-2ev. Anyway, I have been working on them on and off since then and finally decided to print a few. I printed one at 20 x 30 and overall it came out stunning - with one small problem - that I have tracked down. I went back to the original and redid everything, because I wanted to remove some purple fringing (the DA 12-24 is famous for this), and I also checked off enabling the lens profile correction for the 12-24 in LR4. Well when I picked up the print at Costco - for $8.99 you cant beat the price, it looked wonderful. Then, I started seeing some digital "sawtooth" artifacts. I knew it was not the printing, and I knew the original RAW images were fine, and really the only thing that I had added was the CA removal and the lens correction.
Well, the lens correction was the culprate here. The more I looked, the more instances I found, all over the image. At a distance, it looks like a million dollars - however, up close - its another story. I went back and reprocessed the whole entire image, without correcting the lens, and its just fine as expected. Other times when I have used the lens correction it has been just fine - but this time, in this instance - it's performance was just terrible.
I was just not expecting this. In any case, it was a $8.99 well spent.
