Originally posted by mtkang I tried to multiple process all edited images by right click 'multiple process' under the laboratory tab.
From the 'Browser' view, select the images you want to work with.
Switch to 'Laboratory' view. It should then display in the tray at the bottom of the screen thumbnails of the images you selected (under 'Edit Candidate images').
Then process the first image with the settings you want to apply to them all. Then go to the top menu, go to 'Image > Copy Parameters'.
Then select all the images in the bottom tray and go menu 'Image > Paste Parameters' to apply the parameters to all files.
Then select menu 'File > Process Multiple Files' and select your file export parameters.
