Originally posted by Mikhail Well I chose LR mainly due to it being non destructive & remembering your settings for each image (no matter the format). LZ has to save a jpeg\tiff every time you edit an image and that just doesn't work with my work flow. Also the cataloguing features, slide shows, printing features in LR beat LZ any day. Also I do like the zone map system of LZ and the "layers".
Thanks
Actually this is not true. LZ does none destructive editing. However instead of collecting the processing info in a database like I believe LR does, it's saves the info in a small jpg file which is associated with the original RAW or JPG file. This does have several advantages over using a database. You have all your data in one place, for example I have all my images on a portable HDD and can work on it at home or in my office, without having to worry about the editing info. It's also easy to create several different version from one image. I do agree that using the database can be less intrusive (although I think you can set LZ that it does not display the jpgs), from what I've heard LZ printing seems to give some people problems. I have not tried it.
Cheers
Jochen
