Originally posted by Liney So now I'm confused about destroying the original image. As with much of the work I do with IT applications, I open a file (document/spreadsheet/image etc.) and start making changes. If I don't save the edited file, then the original is still untouched as I have been editing a copy.
If I open a RAW image and edit it, but don't like the results then I will not save the changes. Are you saying that I have changed the original? If I like it that much that I want to keep the changes I will process it and save it as another format (mostly jpg), which is a file with the edited changes included. As I have saved as a new image, then the original file I started editing should be intact.
Am I missing something?
No. As long as you don't save and overwrite the original file, you haven't destroyed anything. You can still start over.
Photoshop layers allow much more flexibility. You could make fifty changes to an image, each on a layer. Then change your mind about change #17 and #32, and just delete the layers that have those changes. The other 48 changes, probably hours of work, are still intact. If you don't mind the extra disk space, you could save that layered file and make those changes years later. (Unless Adobe made your file format incompatible.)
The only times I ever have such a complex document, it is a stitched panorama. Photoshop does them by making each image and its modifications into a layer. It may distort or mask an image to fit with other images. Sometimes I want to improve on the automatic stitching process. It's easy to find the layer and change that.
