Originally posted by tim60 At last I have seen someone who has observed and can explain an effect which bothered me.
I have used Epson 435 printer (general purpose inkjet) with glossy photo paper and found that the ink seems to sit on the surface. Grossly disappointing results, glossy for some lower density parts and matt finish for the darker parts of the picture, and the ink deposit can be rubbed off, making them unsuitable for handling.
What is the solution?
I note that none of the packets of materials states technical detail about compatibility.
It sounds like you might be fighting two battles. One is with the printer itself. The other may in fact be a paper/ink mismatch which exacerbates the problems with the printer. The ink rubbing off is strong evidence for a paper/ink mismatch. After realizing my mistake I wanted to be sure of what I was seeing and ran water over one of my test prints. The ink rinsed right off the paper. Either way, choice of printer or choice of paper, I agree that taking your pix to Walmart might be a better solution and cost less than the ink and photo paper used to print a batch of photos at home on your all-in-one. Take a moment to read
this for some insight.
If you're committed to making your own prints and want better ones that will last long enough to become "attic treasure" for your grandchildren I would suggest purchasing a dedicated photo printer. Pigment based ink seems to have maintained the "archival" edge but I understand dye based ink is catching up. Dedicated photo printers can be found at a range of prices.
This article is a decent primer and not too old.
Seeing as how you're using an all-in-one printer for your photos I'll assume you don't want to spend $1000 on a dedicated photo printer, at least not right now. However, there are two very good reasons to opt for a dedicated photo printer you might have to budget and save for. The first is reliability. I took a risk on the 3880 because my experience with the R-800 was dismal; worse than dismal. I spent so much time effort and money on ink and paper trying to fight constant clogs that I had to stop printing for while. I was throwing good money after bad.
After I moved to Southern California and got settled in I started thinking about printing again and did the research. The Epson 3880 came up again and again as, "the one to buy". I rolled the dice, gave Epson a second chance, and have been satisfied as a result. The 3880 works, has done so for a considerable amount of time, and in the long run has cost me less than owning an R800 did (two actually; one was a refurb to replace an out of warranty troublemaker). Much of the cost savings have been due to the larger ink tanks in the more advanced 3880 (assuming the R800 would have been as trouble free); paper didn't get less expensive.
Most larger more advanced printers with a higher initial cost usually incorporate higher capacity ink tanks. The savings in the cost of replacing larger cartridges tends to mitigate the initial cost of the printer. In particular, the Epson 3880 is delivered with full cartridges, not starter cartridges, and that brings the cost of the hardware down to about $620.00. What that means in real world terms is that after the ink lines have been primed you'll still have some ink remaining to do a good bit of printing before replacing any cartridges. Priming the lines uses about half the volume of each cartridge.
As usual YMMV.
