Im needing some good advice on what Panorama software to either purchase or download that suits my needs.
Ive used Microsoft Ice a little with my Point and shoots in the past with single row , and a bit with the K30 on single row.
Also tried PTGui free version last week with the K3 and single row.......When I say "a little" that means less than an hour on the later.
Mainly I will be doing at the most about 6-8 shots in up to 3 rows (24 Shots)
Most often I will be doing 4-6 shots in 2 rows(12 shots)
My first #1 requirement is that it (((preferably))) will be supported for RAW import/export .
My Second #2 requirement it not be limited to smaller files , but can handle large if needed (see above)
Almost bought the PTGui simply because I have a 10% off coupon.....That makes it about $170 and alot of people use it for extreme Panos , which I probably will not do as I have no desire to so may not need anything even close to it ?
Almost bought Photoshop , but then heard it would only support up to about 300mb so I passed without knowing anything else pertinent to the above.
However I have NO idea if I need to purchase "anything" as maybe there is something available that is free ?
Im just beginning to shoot and play with RAW so I dont even know for sure if I need it to export the final image in RAW , but do think I need it to be able to handle RAW images ?
As you can see.....Im rather lost , and just dont want to make a bad decision for me.
****Currently Im running Canon software for image processing that came with a Prosumer Camera about 4-5 years ago. I kept the disk , but returned the Camera the 3rd day ( worse I ever owned ). I need updated on everything badly ! But....the pano software wasnt bad at all .
Can some of you experienced point me in the right direction ? Thanks !
