Originally posted by RGlasel Wireless is never going to be as fast as even USB 2.0. The time it takes to dig the USB cable out of your bag and plug it in will be saved before you finish transferring your second RAW file.
I'm sure you are right about wireless speeds for handling large numbers of RAW files. I would probably only use it for a small amount of browsing and uploading only a handful of images. It would be worth a try since using a 8 inch tablet with a OTG connection to a drive is kind of awkward. That would not be the primary reason to get the Colorspace UDMA though. I am thinking about using it mostly for backup for light weight travel when not even carrying the tablet. If I get one then I would play with the wireless to see if I could come up with any kind of acceptable workflow for working with images on the tablet. If it doesn't work no harm done.
