Originally posted by PDL You copy the Makers Notes information -Composite:LensID into -exif:LensModel.
PDL, thank you for this info - it works!
I also work with C1Pro and in total I'm very happy with this tool. Especially since version 8.
I also use exiftool. For those who are interested and have installed exiftool I'll show some concrete commands. If you try to use them please work with copies of your images and always keep backups! You do this at your own risk. Now three examples (exiftool command line version):
1) PDL's suggestion - generate -exif:LensModel so that the lens description is shown in C1. Open a terminal window (mac OS X, linux, windows(?)) and go to the image directory and type in the command.
filename.ext you have to substitute with the filename of your picture. If you only type a . (dot) instead of the filename, every image of the directory should be processed.
command line> exiftool '-exif:LensModel<${Composite:LensID}' filename.ext
If you don't want exiftool not to generate backups of your files you can type this:
command line> exiftool -overwrite_original '-exif:LensModel<${Composite:LensID}' .
To see the lens description in C1 you have reload the meta description of the image via context menu.
2) Show all meta data of an image (I set some options to get a readable output):
command line> exiftool -e -a -u -G -s filename.ext
If your camera / image file supports shutter count information, it will be shown.
3) I use exiftool to rename my DNG image files so that the shutter count of my K-5 is part of the file name.
command line> exiftool '-FileName<${dateTimeOriginal}_K5_SC${ShutterCount}.DNG' -d %Y%m%d_%H-%M-%S *.DNG
If you'd like to see a full list of supported Pentax Tags you get it here:
Pentax Tags
Have a nice day
